Yeah… my Kryall brand white can has barely any pressure (I know that it isn’t empty. I only used it a couple of times). Any suggestions?
Only advice I know is not to let it happen in the first place, I’m afraid.
Can you replace the nozzle easily?
Not that I know of
Are you turning it upside down and spraying out the remains in the nozzle after use?
… oh. Didn’t think about that
put it in hot water, not boiling out of the tap is good enough, 3 minutes
Shake the hell out of it at least a minute
back in the water bath, for another couple of minutes
shake the hell out of it, up to a minute
if it won’t spray then it’s blocked and there is nothing you can do.
That sounds good I’ll give it a try as soon as I’m able
Spray it upside down to get rid of the excess (unless it’s one of the fancy ones that can spray at any angle) and wipe it off.
That’s what I meant by preventing it from happening in the first place.
