Loot is the move reduction when carrying a core reduction is you can still at double or is it a maximum total reduction to 5 Thank
Unit become Sp 5 (and loses nimble), so can still at the double 10" ( unless shambling or in terrain as normal).
@DarkBlack is correct. Your speed becomes 5 ( unless it was lower already eg dwarfs, abyssal dwarfs).
Also worth knowing that
- if it’s a shambling unit then they can no longer be surged
- the enemy can’t wind blast you either
thank you …
