UNIT ROLES IN KINGS OF WAR
This article was inspired by a recent Countercharge Podcast episode on unit roles for Kings of War. In it, the hosts did a solid job of describing all the potential roles that the units in your army can fill. But if I’m being honest, they also made it much more complicated than it needed to be, with more than 15 categories listed!
Now I would never profess myself to be an expert on Kings of War – despite playing since late 1st edition I currently only get about 6-12 games per year. BUT, I do like to think about KoW a lot, and I have the time and motivation to spit out a few thousand words on the subject! So with the preamble out of the way, on to the meat and potatoes…
To me, I think you can adequately summarise what your roles your units can be assigned to in KoW with just six categories:
- Hammers: Units that kill units. The pure damage dealers.
- Anvils: For holding ground and absorbing enemy charges without breaking.
- Chaff: Disposable units for disrupting and delaying the enemy.
- Board Control: Limiting enemy mobility by controlling large chunks of the table.
- Shooters: Units with ranged attacks, for wavering and weakening enemy units to finish off in combat later.
- Support: Improves the rest of your army with beneficial Auras, Spells and Orders.
That’s the TL:DR version. But it’s worth going into more detail with how these roles work, as well as some of the sub-roles you can divide them into;
HAMMER:
Units with the highest damage potential in your army – these are usually what you can count on to charge in and take enemy units off the table.
Traditional Hammers: The kind of high-end unit that will deal 10-12 damage vs Defense 5 on their own – enough to all but break most infantry regiments and put a massive dent into anything bigger. If you can keep them unmolested they’ll do work. But they also rarely cost less than 200 points, and will absolutely be the units your opponent will focus on. Examples: Shieldbreaker Hordes, Knights, Ogre Warrior Hordes, especially when buffed with Magic Items or Bane Chant.
Lite Hammers – The cheaper, less deadly little brother of your big Hammer units, who typically deal closer to 4-6 damage vs Defense 5 in combat. A single Lite Hammer is rarely enough to wipe out an enemy unit on their own. But the potential is there to grind down the enemy over several turns, or help to sweep something aside with a multi-charge. Examples: Ogre Warrior Regiments, Foot Guard Regiments, Giants.
Flank Hammers: Deals massive damage proportional to their cost via flank charges. To be honest almost any unit can be a Flank Hammer – it’s just a matter of positioning and opportunity. But some units are better at creating those opportunities than others, in particular flyers and small based heroes or monsters. Examples: Heroes without Individual, Knuckers, Tortured Souls, Goredrake.
ANVIL
The damage soak, designed to reliably absorb charges from enemy units, and ideally hold them there for multiple turns. That’s not to say an Anvil should be considered invincible. Flank charges, Multi-charges and particularly strong Hammers all have the potential to remove even the toughest Anvil-type unit in short order. Rather the value of an Anvil comes more from your opponent needing to put more resources (points value) into killing such a unit, than what the Anvil itself is worth.
Traditional Anvils: Much like the Traditional Hammers, these exemplify what it is to be an Anvil type unit. With some combination of Defense 5-6, horde-level Nerve (ie. 21+) or Ensnare they’re very capable of surviving a charge from almost any enemy unit. Then rules like Regenerate or Lifeleech can ensure they’ll stay around for subsequent turns. Examples: Earth Elemental Regiments, Abyssal Guard Hordes, Pike-armed Dogs of War.
Disposable Anvils: Straddling the line between Anvils and Chaff (see below), these units can usually survive a charge from any single unit smaller than a Traditional Hammer… but aren’t expected to last much longer. The advantage they offer is in cost – they’re usually able to do the same job as an Traditional Anvil for fewer points, even if only for a turn. So long as they can hold the line long enough for your own Hammers to do their work, that might be all you need them to do. That combination of resilience and low cost also makes them great for guarding an objective in your back lines or an otherwise isolated part of the table. Examples: Zombie Hordes, Ironclad Regiments, Regiments with the Phalanx rule.
CHAFF
The cheap and disposable speed bumps. These units are there to disrupt and delay your opponents units, usually by getting in the way and preventing them from charging your more important units. They’re almost guaranteed to die in the process, but that one turn of delay, or that chance to counter-charge with your more dangerous units, makes it more than worthwhile.
Trash Chaff – Also what you might think of as “traditional” chaff, these are the low cost Auxiliary units like swarms and infantry troops. Pillow-fisted and likely to die to a stiff breeze, their only saving grace is that they’re usually the cheapest units in the army list. If you want a unit to just get in the way for a turn, Trash Chaff are your most efficient choice by far. Examples: Imps, Ironclad Troops, Zombie Regiments.
Fast Chaff – Chaff, but fast! You pay extra for the higher speed, but that also makes them the ideal chaff unit to screen your Knights and other fast flankers. The higher mobility of Fast Chaff also makes them much better at jumping into the fray exactly where and when they’re needed. If you save them for the late game, they can also be used for claiming objectives or hunting down warmachines or individuals, making them more of a multi-role unit than the much cheaper Trash Chaff. Examples: Gargoyles, Snow Foxes, Fleabag Riders.
Thicc Chaff – Still cheap enough to be considered disposable, but with just enough punch and resilience to clear out other Chaff AND require something half-decent to wipe out in a single turn. Thicc Chaff are usually also a genuine threat should they manage a flank charge, making them a unit your opponent will regret ignoring. Examples: Dwarf Berserker Troops, Ogre Warrior Troops.
BOARD CONTROL
Units who can lock down parts of the board with their extended threat range, thanks to either a high charge distance or strong shooting attacks. These units will limit your opponent’s mobility just with their presence on the board, usually helping to either protect your own flanks or threaten enemy flanks.
It might seem odd to put high speed cavalry and flyers in the same category as the more static shooters like War Engines and shooting infantry. They do, after all, have almost polar opposite styles of play! But when you boil it down to their effect in a strategic sense, they’re both denying a chunk of the table to your opponent. Still, they neatly divide into two sub-categories;
Ranged Denial – Shooting units that can command a large field of fire. They hold the line and discourage the enemy from coming forward or even deploying in that area. War Engines with good damage output for their cost can be great at this, especially if your opponent isn’t well equipped to hunt them down. However a horde of ranged infantry might prove too much effort for your opponent to try and shift, making them an equally solid deterrent. Examples: Decimators, Ironwatch, Halfling Rifles, War Trombones.
Flankers - Fast units like Cavalry and Flyers. These can aggressively move up to take territory, threaten flanks and hunt other vulnerable units. It may come as no surprise that Flankers tend to become Hammers if they get the chance to flank-charge your opponent’s units. This is also why they function well as Board Control – their presence forces your opponent to play defensively and protect their flanks. Examples: Orc Gore Riders, Frostclaw Riders, Abyssal Archfiend and other dragon-type Warlords.
SHOOTERS
Units that can soften up the enemy by dealing damage to them at range, usually to either waver enemy units and disrupt their advance, or damage them enough for other units to finish off in combat. Shooters can be a great counter to Chaff, with their lower Nerve making them easier to Waver, or even Devastate and break them. But even just dealing a few wounds to larger units can be enough to tip the balance in your favour, once you engage them in combat. Examples: Halfling Rifles, War Machines, Blizzard-equipped Wizards… lets face it, this is literally any unit with a damaging ranged attack.
Missiles – Basically units with the same role as Shooters, but they deal their damage in combat instead of at range. Realistically, this is more of a secondary role for Chaff units. They’re cheap enough to throw away on a hopeless charge, they’ll hold up that unit for a turn (as is the purpose of all Chaff) and the damage they do will weaken that unit for the inevitable counter-charge. Examples: See “Chaff”, above. Thicc Chaff in particular do well in this role, thanks to having some respectable damage output in their own right.
SUPPORT
Units that improve the effectiveness of their army. These are usually (but not always) characters with access to Inspiring, Commands, Auras or beneficial spells (eg. Healing, Bane Chant). This should all be pretty self-explanatory.
In the broadest sense, Support units simply make the rest of your army better. But you can also consider them as units that can shift the roles of those units too! For instance a Bane Chant spell can turn an Anvil into a Hammer, while an order granting a Fireball attack could turn some cheap chaff into a Shooter. In other words, Support units have the potential to grant some great flexibility in what the rest of your army is capable of.
Examples: Almost every Warlord and Commander in the game, The Well of Souls, Ratkin Tangle, Steel Behemoth.
I’m going to leave it at that for now. If you got this far, thanks for reading! I’m always happy to hear feedback, so if you have something to add (or dispute) then by all means, do so!
