With the amount of 3D printers increasing, I thought it could be good to have one place for suitable KoW terrain, checked and curated by the community. I’ll start!
Elven watch tower: https://www.thingiverse.com/thing:2610039. I have made two of these, and they look rather nice. The scale is just right and they’re easy to put together, store, and transport.
Elven waystone: https://www.thingiverse.com/thing:2443707. I have made four of these. They’re very impressive looking in person! Here is one unpainted, but you’ll get the scale.
And because I can only post two links in a post, here’s a second post:
Elvish walls: https://www.thingiverse.com/thing:1401691. I have a plan to scale these up and print out several for a diorama. The only downside is that they can’t be used as are for a siege game, because they lack ramparts. Otherwise, I think they’re rather neat!
There are a ton of buildings as well. Some with a lot of detail Thingiverse. Searches under DND and 28mm usually have them pop up. There is also a bunch of scatter terrain out there as well.
Love my 3D printer. It’s been going pretty much non-stop since I got it 2 months ago.
Edit- you can also scale things up or down to fit 10mm or scale up smaller things to make monsters.
I’ve printed a bunch of Ulvheim, mostly for Vanguard but also works as impassable for KoW. Just started on some hills from the same creator (terrain4print) which I have scaled the height down to 30mm so hopefully stuff falls over less (but kept the X and y the same). https://www.thingiverse.com/Terrain4Print/about
