I am looking for a manufacturer of some better looking (than the Mantic Dwarfs) and reasonably priced minis with a consistent look - all should be heavily armoured
1H Weapons and Shields
Spears and Shields
2H Weapons
Long Rifles
Oathmark will sort the first three - they have a regular dwarf kit (standard chainmail type) and a heavy dwarf one in full plate - the former have hand weapons/spears, latter hand weapons/2hw. Kits are cross compatible
They may not look like much, but I have seen some easy paint jobs that fix them up to look great. Also the Crossbow can be easily converted to a rife. At 25p a model, I think you’ll be hard pressed to find cheaper.
Avatars of War have really cool miniatures and in theory an alternative for all infantry units but Bullwalkers.
But it seems they are not able to produce them regularly, so you have to be lucky to get some.
Another option could be Scibor. If you like their style, you get a lot of units there.
And then there is MOM from Spain. They recently increased their dwarfen range and you can even get a Zeppelin, a giant throne or a huge axe thrower (if you remember GW Slayer engineer and his war machine).
I was not completely happy with the quality of the oathmark miniatures - especially the 2h weapon ones - i found it impossible to get some of the arms to match up on some of the weapons as the beards would get in the way.
they are also quite small - ie true 28mm - in comparison to Mantic and GW it’s very noticable.
luckily for the most part the army is oathmark. I am just thinking that the rank and file is your average dwarf citizen warrior, while the characters are the better fed ones
the scibor miniatures had the opposite problem - very large. those i am using as the better fed ones.
