I have searched the forum but couldn’t find an answer so sry if I missed it.
The rules say that if you counter charge a unit that you are engaged with the the flank or rear you " turn it to face the target and align it flush with the target’s front face", so at this point should the combat last (via counter charge) into further turns, you are not engaged in the flank/rear any more which is a massive advantage.
What happens if due to your unit foot print and surrounding terrain and/or units you cannot turn your unit to face a unit in your flank or indeed if you do not want to turn your unit to the flank or rear, can you still charge using the flank / rear of your unit in this instance?
Thanks!
John
