Hello! I had an odd situation pop up recently. Essentially, do Counter-Charges count as declaring a charge, for the purposes of resolving a multi-charge? (Will they slide and make room for a new unit charging in?)
On his turn, my opponent (green) charged a Horde of Large Infantry and a Regiment of Heavy Infantry into two different infantry regiments of mine (purple). Both hold, and are not wavered.
On my turn, I have a third infantry regiment in reserve, and want to get all three into the fight, with two going into the Large Infantry Horde.
I ended up disengaging the charged unit from the LI Horde, moving back 1”. I then declared a multi-charge, with both regiments against the LI Horde. This would be the only way to make that happen, right? Or would a counter-charging and newly-charging unit count as a multi-charge, and shuffle appropriately?
