Data and Dice
Cheers mate - some interesting stuff again.
That’s quite interesting.
The insight that instigation and threat projection are important is intriguing. If that’s the case, why not brew of haste and mead of madness?
I wonder why top players avoid the blade of slashing though.
That’s the one that throws me. Could be noise? I may look into how I could incorporate a larger dataset from multiple tournaments. Would require some data cleaning but seems doable.
Think it may just be that the 5pt stuff is used at the end to fill a gap, rather than part of possibly better planning?
Looking at what was taken by the top percentile (outside of boots and GGS which seem to help!) could be interesting.
I’d guess that the artifacts were really focused on enhancing good units, rather than buffing mid rank ones or using leftover points at the end.
Also bit odd is that since Blade and Mace are (excluding a few situations) statistically the same, the former was taken a lot more.
It could be that blade of slashing is a go-to for everyone with 5 points to spare, but higher rated players have been favouring fire oil instead?
For low att heroes the reroll is effectively an extra attack, while the mace doesn’t matter if you don’t hit (or have the CS to damage with all hits often).
That the ‘feeling’ the items give - similarly that I’d give elite to units with better Me and vicious to those with better CS - even if ultimately, from a stats perspective they both increase your chance of ultimately causing a wound.
I went ahead and added in aussie masters and french masters, where I had data ready to go. Beefed up the data set.
Here’s the full table (sorry for the formatting)
item_name Top_% Bottom_% Gap
Sir Jesse’s Boots of Striding 50 28.6 21.4
Gnome-Glass Shield 16.7 0 16.7
Blade of Slashing 10.4 26.5 16.1
Fire-Oil 14.6 2 12.6
Healing Brew 2.1 14.3 12.2
Tome of Darkness 12.5 2 10.5
Hammer of Measured Force 4.2 14.3 10.1
Pipes of Terror 2.1 12.2 10.1
Sacred Horn 4.2 14.3 10.1
Conjurer’s Staff 8.3 0 8.3
Inspiring Talisman 4.2 12.2 8
Dwarven Ale 8.3 2 6.3
Diadem of Dragonkind 0 6.1 6.1
Staying Stone 22.9 18.4 4.5
Lute of Insatiable Darkness 16.7 12.2 4.5
Trickster’s Wand 12.5 8.2 4.3
Axe of the Giant Slayer 4.2 0 4.2
Shroud of the Saint 2.1 6.1 4
Aegis of the Elohi 2.1 6.1 4
Ej Periscope 6.2 10.2 4
Brew of Haste 10.4 8.2 2.2
Blade of the Beast Slayer 4.2 2 2.2
Talisman of Silence 4.2 2 2.2
Boots of Levitation 4.2 2 2.2
Hann’s Sanguinary Scripture 6.2 4.1 2.1
Liliana’s Tear 2.1 0 2.1
Mace of Crushing 2.1 4.1 2
Piercing Arrow 2.1 4.1 2
Crystal Pendent of Retribution 2.1 4.1 2
Banner of Eternal Darkness 0 2 2
Chalice of Wrath 10.4 10.2 0.2
The Boomstick 2.1 2 0.1
Wings of Honeymaze 2.1 2 0.1
Wine of Elvenkind 2.1 2 0.1
War-Bow of Kaba 4.2 4.1 0.1
The Scrying Gem 2.1 2 0.1
Zephyr Crown 2.1 2 0.1
Amulet of the Fireheart 6.2 6.1 0.1
Mead of Madness 2.1 2 0.1
Skirmisher’s Boots 4.2 4.1 0.1
Scythe of the Harvester 4.2 4.1 0.1
I think this is right. It reminds me of the furor around the monty hall problem–people feel something intuitively, and it’s hard to shift. It’s an easy math problem to test and see, but on fanatics you have people who feel passionately one way or the other.
Also the blade is the first 5-pt item listed, so that makes it easier to select.
A quick data analytics dive into 2,600 tournament games to see how lists perform.
Interesting!
I wonder if the number of scoring units and volume of attacks migh interfere with each other?
More units come more attacks and units with US usually have more attacks than heroes.
Trash units/ofjective sitters often have lots of bad attacks, which might drive up the average?
Is the number of attacks only the att stat (i.e. melee) or does it include shooting too?
I track both total attacks and total ranged attacks separately. I’m sure theyre correlated with US. But frankly all of the effects I see are pretty minor–even with 2,600 games in the dataset, the best model I can generate is only marginally better than a coin flip. So list building matters, but it looks to me like player skill matters much more.
New army review up:
Interesting - will watch this space.
One quick update:
I built out a little webapp for scenario/map randomizing. If you want any additional features, let me know, and I’ll build them out. You can test it here: Streamlit
Nothing fancy, just a quick randomizer.
Top 10 Reasons to Start Playing Kings of War (Especially If You’re Coming from Warhammer) - Kings of War Data Analytics | Data & Dice Blog
Fancy having a little data look into a 34 player, 5 game 2-dayer?
https://thenorthernkingsresults.com/index.php
Lists and matchups/results can be found on each player’s profile.
[As an interesting fact - the winning list included an artifact only taken once out of 196 players at uk Clash last year!]
There’s no chance it’s saved on the Mantic Companion somewhere, is there? That would make the data cleanup infinitely easier.
I don’t actually know - they’ve always had a separate website for results etc, not sure if also ran on Companion
