Hi,
Can any tournament players give advice on a decent KOM 2000pts tourny list? I have plenty of models so go your hardest! All those who reply will be guaranteed a place in Heaven!
Cheers,
Dingougly
Here’s an opening shot from me, a person who doesn’t play Kingdoms of Men
Army: Kingdoms of Men
Unit Count: 14
Unit Strength: 23
240, Spear Phalanx Horde
– Pikes
– Indomitable Will
235, Foot Guard Horde
– Indomitable Will
– Indomitable Will
105, Pole-Arms Block Regiment
100, Mounted Sergeant Troop
190, General on Winged Beast
90, Hero on Pegasus
120, General
– Horse
90, Wizard
– Inspiring Talisman
– Lightning Bolt (3) to replace Fireball
– Bane Chant (2)
100, Cannon
100, Cannon
General on horse could become The Captain on foot, if you fancy his redeploy ability, tho I rate the speedy General for helping in combats and telling flyers to sit down if needed. Pole-Arm regiments could become Bowmen regiments (with 10 pts left over) if you fancy tossing some shots down range instead of combo-charging / hunting for lucky CS1 flanks. Their survivability is identical and they both unlock for cheap.
Slow steady and violent!
Base is fairly similar to the above one (which I hadn’t read when pulling this together) so shared things are probably solid choices!
Compared with the other, this basically drops winged beasts down to pegs, tools up the hordes and has extra polearm over light cav.
Unit Count: 15
Unit Strength: 27
260, Spear Phalanx Horde
– Hammer of Measured Force
– Pikes
– Indomitable Will
275, Foot Guard Horde
– Brew of Strength
– Indomitable Will
265, Foot Guard Horde
– Blessing of the Gods
– Two-Handed Weapons
– Indomitable Will
95, Hero on Pegasus
– Blade of Slashing
90, Hero on Pegasus
115, Wizard
– Horse
– Bane Chant (2)
115, Wizard
– Boomstick
– Pegasus
75, Army Standard Bearer
– Lute of Insatiable Darkness
100, Cannon
100, Cannon
90, Siege Artillery
Hi,
Some great ideas there, thanks very much. What do you think of Fanatic horde instead of Foot Guard?
Cheers,
Peter
You basically swap damage output for defensive capability - nothing wrong with them but more vulnerable to basic shooting
ok thanks.
I dig Fanatic regiments personally, have been using similar Me 3+ WC regs in other lists and enjoying them. I think Indomitable Will sorta devalues their fearless when it comes to hordes, plus you can make Foot Guard hit harder, you can’t really make Fanatics survive better.
Hi,
I think you’re correct. I have a number of Gauls/celts that make good fanatics and I like to use them sometimes but Foot Guard are more sensible!
i haven’t been playing long but i’ve been studying with the help of friends who have. and i have come to the general conclusion that less durable units like fanatics need to be paired with defensive units. either larger durable units like pikes or footguard with the fanatics acting as flankers, or chaff meant to keep the enemy away from the fanatics for a turn so they can get in a punch before taking damage.
so for this army i’d suggest replacing the Polearms with Fanatics, rather than the footguard. the footguard and/or pikes acts as a bulwark the enemy will get stuck on, which will let you use the fanatics to hit the sides. it might also be a good idea to either drop the singular pike horde and stick to two hordes of footguard, or drop one horde of footguard and replace the other with more Pike’s. use the points saved to add some more mobile units like Knights or mounted sargents, which can threaten the opponents backfield and give the chance to grab objectives. (the mobile forces in your current list are all individuals, which lacking unit strength cannot claim objectives)
Hi Mithrilcoyote.
yes the fanatics need chaff to protect them from charges but this means they are disadvantaged re Wildcharge D3.
Cheers,
Dingougly.
ps I see a canine theme here: coyote and dingo. Very X files!
