Did I understand that correctly? So if I’m standing still, a LB or fireball can hit you on a 3+ ? If the target is not in cover yada yada yada.
This is correct! ![]()
On the other side you only hit on a 6 if you cast at a unit with Stealthy and Spellward. And characters have to move often, because they won’t see anything, you need their inspiring, they a6in a dangerous position,…
