Lost Kingdom Miniatures - 28 or 32mm?
I am thinking about buying this lot:
Do any of you have any experience with the scale of Lost Kingdom Miniatures? Should 28mm be enough or should I order 32mm?
They would be used mostly beside GW Lizardmen.
Thanks in advance!
This is done at 28mm and the other models are fireforge/victrix.
Unless you are solely using the old monopose style sarus models I’d go 32mm as the gw stuff tends to be bigger/heroic compared to historical ranges
I think you will find the answer on this channel. He unboxes Lost Kingdom Minis and compares them to other companies at the end
