I have a question regarding this rule:
During the Movement Phase of your Turn, pick each of your units, one at a time, and give them one of the following Movement orders. Complete each order and any movement with a unit before proceeding with the next one.
I can read it in 2 ways, which one is correct?
- give each unit a movement order and then execute each order
- give a unit a movement order, execute it, go to the next unit, give a movement order, execute it,…
The difference? Imagine 2 troops, one after the ohter. The first one sees in front of him a unit and also another unit which it can charge because it can also fly. The second one doesn’t have LOS since it is behind the first one. If the first unit movement order is executed first, then the second can receive his order en charge the unit in front of him since it has now LOS.
