Was messing around on EasyArmy, came up with this list. Thoughts? (I haven’t committed to about half of these, yet)
Nightstalkers
Scarecrows (Horde) 130
- Blade of Slashing 5
- Screamshard 5
Doppelgangers (Regiment) 145
Butchers (Regiment) 125
Mind-screech 150
Fiends (Horde) 215
- Maccwar’s Potion of the Caterpillar 20
Portal of Despair[1] 90
Shade 135
Horror 65
- Aura (Vicious (Melee) - Infantry only) 30
- Bane Chant (2) 20
- Weakness (2) 15
- Mind Fog (2) 15
Planar Apparition 165
Esenyshra, the Wailing Shadow [1] 160
Scarecrows (Regiment) 80
Mind-screech 150
Reapers (Troop) 135
Total Unit Strength: 21
Total Units: 14
Target Points: 2000
Core (Target%): 2000 (100%)
Lots of great stuff going on. I myself would drop the Scarecrow upgrades, swap the Reaper troop into a second Butcher regiment, give the Shade a weapon (Blade of the Beast Slayer > Axe of the Giant Slayer > Scythe of the Harvester > Mournful Blade I think in that order), and change the Horror’s mind fog into Conjurer’s Staff. If you wanted the Scarecrow regiment to be a horde, you could easily mine the points from the Horror’s aura + weakness.
EDIT: I’m not 100% on the Horror aura without going heavier on non-Me 5+ infantry. Even with the Reaper troop I took away to give you the more dedicated thicc chaff Butchers, just not much benefits from it. If you dropped it, you could go ultra spendy and give the Fiends Brew of Sharpness. ‘Negates’ hindering but also tears faces off in the clear.
Thanks
I’m not super familiar with army building, so this was exactly the type of response I was hoping for! (Y’know… before I spend even more money on minis)
With spellcasters, unless they come with multiples [Edit- "multiple spells - so don’t have more than 2 spells unless you start with more], don’t get more than two - it tends to be a waste of points and having a couple of casters with 1/2 each often better.
So, having two Mind-screeches, a planar apparition, and a horror is too many casters?
Sorry - don’t get more than 2 spells on each caster
Gotcha. Yeah, I can see that
