Hello all-
New Kings of War player here, returning to the hobby after a 20+ year layoff.
I was formerly involved with 40k when I played, so movement trays and multi-basing are new concepts for me.
I am shooting for a fairly modest painting standard, and have researched what I’m going to attempt there. But it’s become apparent quickly that I need to decide on how I’ll handle basing, sooner rather than later.
I want to sort of temporarily base my models during the painting process, because this is what I’m familiar with, and it’s necessary for my dexterity/skill at the moment. I’ll use the bases supplied rather than ice lolly stocks or whatever else, because I’m familiar with that. I’m proposing to use a minimal amount of superglue on one foot to secure the model, then when it’s completed, I’ll ‘snap’ the model off without damaging it.
Anyone got any views on this process -is it risk free with hard plastic models, or should I be concerned about damage to the model?
I will then either discard the base, in favour of gluing the model to a pre-prepared multi-base from Warbases, or I will properly finish the base neatly, and then re-glue to the base properly, and slot the bases into a movement tray from Warbases.
Whether I use movement trays or multi-bases, I’m planning on using PVA glue dipped in Base Ready, with some strategic addition of rocks and tufts of grass. I know it’s a far cry from the sculptural DIY dioramas I see experienced KOW players do, but I think this is a level of finish that is about right for me at the moment.
If I order the 3mm KOW warbases base, and cover with Base Ready, some rocks, some tufts, and glue the models directly on, and edge the base with black for contrast, is this is an OK approach - will the overall unit have the right height? Will them be relatively easy to move around in a casual game?
My other option is, as mentioned, to remove the bases, finish them properly, and then reapply the whole lot in a movement tray. I’m pretty sure I actually would want to glue them into the movement tray, to avoid having them rattle and move around, fall out etc.
It seems that with either of the options above, I would probably look to multi-base the units in smaller unit sizes, troops or regiments, so that I have some flexibility in terms of fielding them at that or larger units, depending on the day.
If my multi-basing approach is viable I would probably prefer that.
Sorry for the very basic questions, but I find that a lot of the YouTube instructional material involving mutlibases is pitched a level higher than I’m aiming for, and incorporates modelling putty, cork and various other materials and just takes things to a level that I don’t want to explore at the moment, for a few reasons (Maybe in the future).
