Hmm that is very few units! If I was fighting it I’d try and chaff up the four heavy fliers, take out the rest of it, and then gang up on the flyers. Let us know how it goes though!
Quite the compact force, like a sock full of coins Good luck out there!
(For posterity, I tried to pressure cook the list to put a second regiment of Tundra Wolves in, but the best I could do is a Thunderseers regiment, which isn’t a bad shout to add some thick chaffing, at the cost of 135 points in upgrades )
Jeh, i would say the same thing, its a heavy list, but lacks drops.
Maybe lose some items and try to increase you amount of units? not every unit needs an item. most are good enough without it.
Everyone with more drops can out deploy you so they have a clear idea were those heavy hitters will go and deploy accordingly.
Play test it a few times, and lett us know if it works.
hopefully i’ll see you at the clash 23
