If a regt. of archers are an inch into woods(H6), can they see out and fire normally at any target within
there arc of fire?
there arc of fire?
Can they see out?
Yes, if the leader point is in the woods.
“If a unit’s Leader Point is in a piece of Difficult Terrain, then that unit ignores that piece of Difficult Terrain when checking LoS.” -p24 core rulebook
Difficult terrain includes “…things like woods, crop fields, areas of rocky terrain or scree, ponds and so on.” -p24 core rulebook
And
“A unit can pick a single Enemy unit as a target for its ranged attacks as long as all the following conditions are met:
• The target is at least partially in the unit’s front arc.
• The unit has LoS to the target.
• The distance between the unit’s Leader Point and its target is equal to or less than the weapon’s or spell’s range.” -p26 core rulebook
Can they fire normally?
Maybe.
“The target unit will be in cover if:
• At least half of its base is within Difficult Terrain, or…
• LoS to at least half of the target unit’s facing that is being targeted passes over intervening units or terrain (including Difficult Terrain the target unit is in contact with).” -pg 27 core rulebook
If they have cover because of this, -1 to hit (so not normally) with the exception:
“A firing unit that received a Halt order in its Movement phase ignores any piece of Difficult Terrain that it is currently within, or in base contact with, for determining whether an enemy unit is in cover, unless the enemy unit is also touching or within the same piece of Difficult Terrain.”
Examples: (these all assume that the woods is deeper than the 1" depth of the archer, thus covering >50% of the enemy base if they are straight ahead)
Hope these help a bit.
yes it does TY
