Sliding through terrain or other unitd
“The Align and the Slide are two separate actions and you need to be able to do the first legally before doing the second and shouldn’t be rolled into one.”
How do you explain this example in the rulebook?
explained by the unit being so wide that there only exists one spot to put it (no room for sliding)
Honestly, that’s still not enough. You also need to include two additional restrictions:
  1. During alignment: Without overlapping any other units (except for Multi-Charges and Yielding) or obstacles (Flyers may ignore both).
  2. During the subsequent Slide: You may not slide through obstacles or other units (except for Multi-Charges and Yielding; Flyers may ignore both).
I’ve only browsed the discussion, so maybe I’ve missed something, but isn’t the critical problem with the first post that the unit no longer fulfills the requirement to maintain “the point of contact”. In all other examples shown in this thread, this requirement is upheld.
Also, several people have used ‘flush’ as a verb or action (flushing & ‘during the flush’). Before any rules get rewritten I would like to point out that what we are talking about is ‘to be flush’ (sitting level and even with an adjacent surface). Saying ‘flushing’ or ‘during the flush’ is wrong and means you are flushing the toilet! :sweat_smile:
Dude, it did Slide. To lhe left. if you only turn & not slide the horde is overlapping with Unit RED A.
Obviously, you don’t need to maintain contact with the initial point of impact throughout the entire charge.
How’s this:
Once the charging unit makes contact with the target, pick it up and [place it] flush with the facing of the target you are charging[. After being aligned, the unit must still be in touch with the initial point of contact. It must also be clear of any blocking terrain and units (except for other friendly units that are also charging the same target). You are allowed to ignore Yielding units while aligning, and units with Fly can ignore all blocking terrain and units. ]
Finally, slide the charging unit sideways until its front facing mid-point is facing directly opposite the midpoint of the facing of the target unit that your unit just charged, or as close as possible to it[, stopping in any blocking terrain or units. Flyers can ignore any such obstacles, only counting as having landed after reaching their final position. You may choose to ignore a Yielding unit but still cannot end on top of it.] The unit and the target are now Engaged.
IF these were the rules in paragraph 6 and 7 - would you feel they described the situation more accurately (regardless of this being the way you prefer it to function)
I didn’t mean to imply that you need to maintain it the whole way through, that would be silly.
I meant that you need to maintain the point of contact at the end of the charge. In the initial example that is not the case. The unit is no longer in contact with the initial point of contact in its final position.
Guess you can play that way in your own house. Go for it.
I feel confident you would quickly get corrected if attending an international tournament, however.
Let’s see if something gets added to the upcoming Errata. We can pick this thread back up after Arrogance drops.
pforson, I think you are treating the initial contact point as a fixed coordinate. In most charge/align sequences it is just where the charger first touches, and the later slide is allowed so long as the charger stays in contact with the charged facing. If the final position is still front-to-front, the original spot on the base can shift. If the rules really require preserving that exact spot, that is a much stricter reading and should be spelled out.
It is, and will be defined better in the Arrogance errata AFAIK.
