Surge tactics
Hi everyone!
I thought it would be interesting to hear how people tend to use surge. I’ve not played a surge army much, nor really faced one, so I’m really interested in hearing the general (or indeed specific) tactics people use.
Obviously, trying to get a flank, but how exactly? I can think of a few ways that might work, but i imagine there are some “classic” surge tactics.
There are a few ways you can use it - some more sensible than others - and it does depend a lot on the army you are playing against/with.
As a general need you will need multiple casters and it helps if they have the ability to multi-cast, get buffs or have artifacts that help (gladestalker druids, supreme ironcaster, stone priests - amulet of fire heart, crown of wizard king, wand of borrowed time). Mobile ones (mounted, flying or boots of levitation) means you can get the caster where you need it.
Shoot then surge - things like ice elementals, upgraded AD golems, EoD guardian archers etc. Move up, shoot something (it doesn’t have to be the unit you are planning on going into - but extra wounds are nice) then get surged into combat. Being able to do damage in multiple phases is great.
Nimble flyers - wraiths, air elementals (units & greater) undead wyrm etc. Does what is says on the tin. Move 10, spin to appropriate angle surge get surged in. Better the squarer the unit for ease of placement.
2nd line - use the surgable units as a reserve, being able to cover enemy fliers or get into units that have been stuck in combat with the front row of your army.
Retreat, shoot surge - armies like dwarfs & AD often have lots of short range firepower and a rock hard anvil. Get the enemy engaged with the golems/elementals, back up and shoot them with magic, fire throwers, decimators etc - then surge the rocks back in.
Surge bomb - get a unit to go weeeeeee into the enemy from a surprising distance! EoD and FoN have surgable units with access to scout and plentiful mobile casters and/or those with scout themselves. Deploy badly and all of a sudden you can get surge charged turn one. A guy at the masters used zombie troll hordes backed up with surge 30+ (morgoth, liche with levitation, 2 revenant kings iirc) and could just fire units silly distances.
Awesome, all good stuff! In a 2300 point army with lots of shambling, how many surge carers would you recommend roughly? I realise it will vary s but, but as a rule of thumb
Probably 1 caster for every 2-3 key surgable units (so discounting things like zombie regiments, etc)
The troll launcher was apparently being called The Railgun :sweat_smile:
Many of my armies (Salamanders, Trident Realm, Herd, Free Dwarfs) have shambling units, but I’d say this is the only way I use surge. Surge keeps enemy flyers honest and allows for (square) shambling units to push around once melee is joined to grab flanks. All my shamblers are ground-based and non-nimble, so the shenanigan potential is much smaller, and frankly, good players don’t really let you get reliable surge flanks off. I find the tougher the event I’m at, the less I use surge.
That said, if you’re playing with shambling units, if you don’t take surge, that shambling is a pure negative instead of a potential positive. So even just stapling the tome to somebody is a requirement. Water Elementals are the only thing I’ve run without a surge caster in the list, as Sp 7 helps them stay relevant without support.
Another surge tactic, you can use it to charge through woods you otherwise couldn’t see through, like when two units are playing chicken and nobody wants to break the tree line to give up LOS. Shamblers can push into the woods and then be surged into contact.
Sometimes I’ll use surge to get extra inches up the table (which I call “exploratory surge” because it’s so random), but I generally see this as a bad idea and only do it if there’s either no downside to rolling max inches, or I don’t care if the surged unit is charged next turn. Like when shoving a Greater Earth up the table :stuck_out_tongue: EDIT: Of if using another (chaff) unit from over-surging into danger, like parking some Mastiffs some inches in front of Earth Elementals and shoving the rocks safely up the table.
Has anyone seen a lot of Surge in 4th yet? I’ve been building non-surge options so far but would love to give it a go at some point.
Depending on the army in question, it’s not as easy to get as many surge casters into the list as in 3rd, esp if your basic wizard type doesn’t have inspiring.
That said, it was the joint 4th most taken spell at Aussie Clash (behind windblast, BC and LB)
One usefull tactic with surgable shooters is to give them a halt order and then surge them into their range or from behind a forest (or across obstacle), so you will be able to shoot after the surge without being penalized for the movement (or cover caused by the obstacle).
Another tactic is to get a control of how far the unit will be surged by placing an individual (or at least a part of any other unit) in front of the surged unit. For example, you want the unit surged by just 2”, so you place another unit in front to block the movement of the surged unit exactly at 2”.
Even if one does not use the surge much (if opponent is careful with exposing any flanks), the army with surge works nicely to keep flyers at check, as the opponents will be afraid to put them behind (or at the flank) your surgable units.
Just a note on your “retreat, shoot, surge“ tactic. It used to be a good tactic, but in the 4th edition the withdrawed unit cannot be surged the same turn.
Yeah, with that and sticky combats it makes some things harder for shambling units - but if you can tie up an enemy you do have a little more time to get surgable stuff into them.
TR look like they could comfortably go light Surge as the Aquamages do have Inspiring and you could give someone the Tome.
Difficult to go heavier than that as none of the Shambling units are Core - its quite hard to get more casters via a 2nd battalion and still have the units to target.
Right now Surge feels secondary to the “stop being Shambling” command. Its expensive to get in lists, in Undead its hard to get a good number on it without investing in a Titan Revenant or the lizard, and it just doesn’t do as much as the simple command.
I would say there are two reasons why we will see less Surge.
Characters with Surge got so expensive that you can’t afford many of them. And the amount of characters is restricted due to the new way armies are built.
But luckily Surge isn’t that important anymore. In most scenarios speed is not so important.
And it feels like the new edition is resulting in close combats way earlier. So shambling units won’t need that extra movement necessarily.
I will try to play even undead with units of zombies, skeletons or revenants, but without Surge.
And I’m not sure if armies with only a few shamblers like Salamanders, Dwarfs, Elves, etc. will do better if they invest the points and and at least one shooting phase in surging them, or just use them without Surge.
It will be interesting to see what mantic do with FoN, which is the first surge heavy army up for a revamp.
The hero cost, withdraw negating surge and other units getting an extra pivot do impact usage.
Take Salamanders as an example - with a warlord choice (who is a bit odd imo?)) you can get core fire elementals, but only one hero actually has surge. The units are good and the GFE is a beast, but …
Mage Priests are solid options as inspiring, but 30pts for surge(8) might be better spent elsewhere given their flexibility. The tome is good and a herald is the same points, but very inspiring
The unique champion who gets all his buffs from FEs doesn’t have surge and is pricy (although FB8 on 3+ with elite, blast d3 and P1 could be really nasty … like once!)
I noticed this week that Hraath Flamespitter isn’t inspiring either! That’s weird enough to smell like a typo to me - is there another non-inspiring warlord in the game??
Kuzlo and madfall, who have gone from auto include to ignore.
A number of the ‘Champion’ heroes aren’t inspiring in KoW, which I can understand from their background - but he’s just a mess? Combat characters on foot aren’t great, he’s got FB but none of the buffs the MP or Z get. Pick him and FE core and you have to use 2 champion slots on MPs for inspiring and surge??
K&M got Inspiring (Self), so isn’t a typo, even if stupid!
If he was a champion it might make more sense, but a warlord?! Madness.
