HIP - hard impact plastic.
Similar to GW or plastic model kits
The regular stuff on sprues. While the actual plastic and the specific manufacturer has changed over time, these can all be treated the same from the old dwarf/zombies to the new xirkaali warriors & trident realm depth horrors.
Newer sets have simple instructions. Many have lettered/numbered parts that form a single model/options - from a simple pair of arms for a gun/2hw (halflings) to complete multipart torsos etc (TR riverguard). The very old models donât have anything, so can be a bit trial and error.
Generally no need to wash sprues. Clip/cut off and use polystyrene cement/plastic glue. Can be cleaned up with file, knife or mold line remover. Described as âhard plasticâ on the website
20 hard plastic Abyssal Dwarfs
8 x Hard Plastic Xirkaali Warriors/Spearwardens
Resin
Multipart kits - heroes, monsters, war machines etc.
Will be a collection of parts attached to (usually) triangular lumps of the same stuff from when they were cast.
These need to be washed and care taken with clean up (as resin dust isnât good for you). Use superglue to build.
Rarely come with instructions, some have lettered parts on the sprue. If parts are bent/warped they can be softened with hot water/hairdryer, straightened then dip in cold water.
Show as resin on the website
1x Resin Abyssal Dwarf Overmaster
1 x Resin Xirkaali Gokluu Dragon Dragon
PVC
Similar to Reaper Bones or Official DnD plastic minis
[This sometiimes gets called Restic in some blogs, but that isnât really an actual material!]
Multiple separate parts, usually bagged up. May have small chunks of sprue/material attached.
Common material for older mantic cavalry models (halfbreeds, gore riders, sister panther riders etc), large infantry (obsidian golems, orc/goblin trolls & older âtiny leggedâ ogres) and the basic mantic giant model. Some single piece âboardgameâ models were also done with this sort of material - TR Knucker and halfling Iron Beast
Mold lines & warping can be an issue. Need to cut, rather than file, off the former. Hot water treatment almost mandatory to get the cavalry halves to fit or straighten spears. Use superglue.
How it gets described is a touch inconsistent!
10 Plastic Resin Abyssal Dwarf Halfbreeds
3 plastic Lesser Obsidian Golem miniatures
3x PVC Plastic Trolls
