Good job ![]()
The Voidwalker base looks pleasantly full for 6 models. I’ve been looking at their stance and trying to visualise grouping them together.
Cheers - fyi there is a 4th elf back left.
First few half elf berserker kitbashes - the TK arms are a bit thin, but hand swaps work as do some head swaps.
Using the mantic adventures (“it’s not a s*dding dragon!”) dragon model for my goredrake (the actual model is the same basic thing, with a resin two headed add-on).
Added a belly ‘mouth’ from the ravagers kit, ragged up the wing a bit with a dremel and gave them hot-water treatment to help with the posing - the body and left wing (as you look at it) will fit within the profile of the 75mm base.
NS building virtually complete (regiment of soulflayers to go) and a pair of TK Infantry regiments will finish that part - then just lots of painting.
